  New Posts New Posts RSS Feed - Bourns SDR0805 in FP Designer, Legend and 3D error
Steve N View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve N Quote  Post ReplyReply Direct Link To This Post Topic: Bourns SDR0805 in FP Designer, Legend and 3D error
    Posted: 31 Mar 2019 at 10:15am
Making a footprint for a Bourns SDR0805-220ML.
When the body is defined as round and the pads extend outside the component legend the Legend radius is reduced to half and covers the pads and the 3D model becomes a rectangle the size of the pads.  The Assembly layer is correct.
Dimensions are 7.8mm dia, 5.3mm high.
Pad is r800_270rt68.
In this case, Bourns provides a STP file so it can be replaced.
Any suggestions for making this part.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 12:24pm
In FP Designer, the Round Body is mainly used for military connectors.
For the Bourns Case Code SDR0805 it would be best to use the Rectangle 7.8 x 7.8 because the Pads are so big they consume most of the footprint.
We'll put this entire series on POD for free download today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 1:15pm
This page was generated in 0.594 seconds.
