  New Posts New Posts RSS Feed - Bottom Mask for Eagle Parts
SteveD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveD Quote  Post ReplyReply Direct Link To This Post Topic: Bottom Mask for Eagle Parts
    Posted: 16 Jun 2015 at 3:30pm
I have a bunch of dip parts that I copied from the TH.fpx.  I translated them to Eagle back in late February.  I was just checking the pad stacks in Eagle and I noticed that the solder mask on the bottom of the board for these parts does not show up on the bStop layer in Eagle with all layers turned on.
Is this a known problem?
chrisa_pcb View Drop Down
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 7:17pm
This should be fixed if you translate them using the latest version.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2015 at 7:23pm
Download V2015.15 pre-release here - www.pcblibraries.com/downloads
You might need to reprocess your DIP library parts.
We made updates to the Eagle interface and cleaned up some bugs.
We stopped adding new features and are 100% focused on fixing every bug in Library Expert V2015.
