Forum Home Forum Home > Libraries > Footprints / Land Patterns > Xpedition
Additional Settings for Xpedition Padstack Export
pildo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pildo Quote  Post ReplyReply Direct Link To This Post Topic: Additional Settings for Xpedition Padstack Export
    Posted: 31 Aug 2023 at 9:30am
how can I define additional settings when generating outputs (Padstacks) for Siemens EDA - Xpedition?
Currently when generating Padstack.hkp files to be imported into EDM Librarian the names for PADs/HOLEs are very rudimentary and do not follow the Xpedtion naming scheme nor the IPC recommendation.
When generating an unencrypted ASCII export I've also noticed that the option "AUTO_GENERATED_NAME" is set for Holes which than isn't true.
Therefore now my question: How can I influence the definition of the pad/hole names and the additional settings as marked in the example?
Thanks.
Poldi
Example:
.FILETYPE PADSTACK_LIBRARY
.VERSION "02.00"
.CREATOR "PCB Libraries FPX Expert"
.DATE "Thursday, August 31, 2023 4:45:42 PM"
.UNITS MM
.PAD "Round 1.28mm"
 ..ROUND
  ...DIAMETER 1.28
 ..OFFSET (0, 0)
.PAD "Thermal 1.635mm"
 ..4_WEB_ROUND_THERMAL_45
  ...DIAMETER 1.635
  ...TIE_LEG_WIDTH 0.307
  ...THERMAL_CLEARANCE 0.1925
 ..OFFSET (0, 0)
.PAD "Round 1.635mm"
 ..ROUND
  ...DIAMETER 1.635
 ..OFFSET (0, 0)
.HOLE "Rnd 0.85"
 ..ROUND
  ...DIAMETER 0.85
 ..POSITIVE_TOLERANCE 0.08
 ..NEGATIVE_TOLERANCE 0.08
 ..HOLE_OPTIONS PLATED DRILLED AUTO_GENERATED_NAME
 ..DEPTH_ASSIGNMENT_METHOD THROUGH_HOLE
 ..DRILL_SYMBOL
  ...ASSIGN_DURING_OUTPUT
   ....SIZE 1.5
.PADSTACK "c128h85"
 ..PADSTACK_TYPE PIN_THROUGH
 ..TECHNOLOGY "(Default)"
  ...TECHNOLOGY_OPTIONS NONE
  ...TOP_PAD "Round 1.28mm"
  ...INTERNAL_PAD "Round 1.28mm"
  ...BOTTOM_PAD "Round 1.28mm"
  ...CLEARANCE_PAD "Round 1.635mm"
  ...THERMAL_PAD "Thermal 1.635mm"
  ...TOP_SOLDERMASK_PAD "Round 1.28mm"
  ...BOTTOM_SOLDERMASK_PAD "Round 1.28mm"
  ...HOLE_NAME "Rnd 0.85"
   ....OFFSET (0, 0)
This page was generated in 0.140 seconds.
