  New Posts New Posts RSS Feed - Add Solder Mask definition for Flex IPC-2223
tboyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tboyer Quote  Post ReplyReply Direct Link To This Post Topic: Add Solder Mask definition for Flex IPC-2223
    Posted: 09 Sep 2014 at 11:28am
Maybe not what allot of companies are dealing with
but to design a pattern for the Flex of a Flex board or Rigid-Flex
board requires modifying the solder mask in such a way that
your software currently cannot build to. See figure 9 of IPC-2223.
I think this would save me valuable time because I currently
have to use the software to create the pattern then go
into Layout pattern tool and modify the pad and solder mask.
Then leave a note in the library that this pattern was modified
for Flex. how it was modified and what it looks like is only
visible through the Layout tool.
This page was generated in 1.238 seconds.
