Silkscreen Polarity Marking Pin 1 Indication |
Topic: Silkscreen Polarity Marking Pin 1 IndicationPosted: 07 Apr 2024 at 3:02pm |
Polarity Marking not necessary for packages that can be inverted during assembly (like a resistor).
The minimum Dot diameter should be 0.40 mm. Anything smaller is too hard to see during the Post Assembly Inspection process. The range for Dot sizes is 0.40 – 1.00. The Dot diameter should be the same value as the pad width but keep it within the range. A dot is normally used, but other symbols like square and triangle can be used. On very dense part placement boards, a line drawn the length of pin 1 can be used, but it's hard to identify it as a pin 1 polarity marker. ![]() |
Posted: 07 Apr 2024 at 3:06pm |
The Assembly Outline is a closed polygon with an assembly reference designator inside it. ![]() |
Posted: 07 Apr 2024 at 3:09pm |
Connector Polarity Marking general guidelines.
