  New Posts New Posts RSS Feed - Why is Gang Mask shape option removed?
ulissescastro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ulissescastro Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 4:34pm
I think the problem is in the resolution and how many decimal points are used, please try to use at least 4 or 5 decimal points in your preferences. I do know is not realistic but please give it a try... Found the Fix, Thanks for helping...
by the way thanks for sharing the FED Vol 18 standard, for some reason I did came up to the same conclusions over the time... are you planning to give a quick update and presentation about it? I'm not sure if we can buy it or what its include on it. so a quick summary may help to justify it ;)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2025 at 4:55pm
I was able to reproduce the issue using 4 place calculations.
When I use 3 places it works OK. But that's because when 4 places are rounded to 3 places, the rounding is up.
Try this - use 4 places and for the Minimum Pad to Pad Spacing use 0.2033.
The new FED Vol 18 Nominal Calculation Mode comes with V25.02 Footprint Expert.
Switch between Min/Max and Nominal Mode in "Tools > Options > File > Calculation Mode > Min/Max or Nominal".
The new feature is located in the "Help > User Guide > Option Settings > Calculation Mode Options".
Post Options Post Options   Thanks (0) Thanks(0)   Quote ulissescastro Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 4:34pm
Thanks. All good now...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 4:41pm
