  New Posts New Posts RSS Feed - Where is the "Build" button?
KipUp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KipUp Quote  Post ReplyReply Direct Link To This Post Topic: Where is the "Build" button?
    Posted: 13 Mar 2015 at 9:53am
I'm using the 2015.09 version of Library Expert Lite.
Where is the wrench/build button? Am I missing something?
I thought The "Lite" tool was able to output several CAD formats.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2015 at 9:56am
V2015.09 has a "Build Part" icon in the Viewer Toolbar. It's the last button.
The Library Expert Lite comes with 21 CAD tool interfaces and every version of every CAD tool.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KipUp Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2015 at 10:03am
Hi Tom, Thanks for the quick response.
My toolbar is missing the "build" button. ....Pad Stacks, Print are the last 2 buttons to the right.
Maybe I should download the "Lite" version again?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2015 at 10:05am
Here it is - I think you might have installed the Library Expert Viewer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KipUp Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2015 at 10:34am
I think you are right Smile
After downloading the correct tool, I have the "build" button.
Thank you Tom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KipUp Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2015 at 11:20am
After downloading new copy of Library Expert Lite, I noticed only some of the Surface Mount and Through Hole definitions displayed the"Build Part" button. The solution to displaying the "Build Part" button consistently was to re-size the graphics window, I'm using 1 monitor, by dragging the "dividing bar" between the "dimension" window and the "graphics window" towards the "dimension window."  Now I see the Build Part" button for all SMT and THRU Hole parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2015 at 11:25am
You must select the OK button. The indicator light in the Viewer cannot be Red, it must be Green.
