Weird looking SOP STEP Models
SDTKO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SDTKO Quote  Post ReplyReply Direct Link To This Post Topic: Weird looking SOP STEP Models
    Posted: 20 Jul 2022 at 5:56am
Hi there,
for some SOP packages FPX produces weird looking STEP models, e. g. for Nexperia 74HCT2G125DP,125. See attached file.
Regards
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2022 at 9:02am
This is because the calculation for the terminal leads is too tight.
The difference between the He and E dimensions is only 1 mm or 0.5 mm on each side.
The L dimension is 0.5.
If you include the nominal c dimension 0f 0.15 for the metal thickness and the bend radius of the terminal lead, there's not enough room to calculate a proper terminal lead.
This Nexperia package is unique.
A normal SOP the difference between He and E is greater than 1.5 mm and the terminal leads will come out proper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SDTKO Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2022 at 5:36am
I see. Thank you, Tom.
This page was generated in 4.328 seconds.
