  New Posts New Posts RSS Feed - Vertical Resistor
Vertical Resistor
plinder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plinder Quote  Post ReplyReply Direct Link To This Post Topic: Vertical Resistor
    Posted: 23 May 2018 at 9:04am
Is there a way to calculate the footprint (and especially 3D model) of an axial resistor mounted and bent in a vertical fashion? I see normal axial resistors in the calculator, and radial dipped resistors but not vertical resistors. I'm hoping I'm just missing it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 9:39am
You must create this part in FP Designer as a round body and remove the courtyard because the one hole with distort the courtyard.
The calculation is simple. Place Pin 1 in the center and place Pin 2 2.00 mm away from the component body.
