  New Posts New Posts RSS Feed - TXS02612RTWR Footprint Issues
toshas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote toshas Quote  Post ReplyReply Direct Link To This Post Topic: TXS02612RTWR Footprint Issues
    Posted: 30 Oct 2017 at 10:45am
Hi!
I downloaded TXS02612RTWR footprint and have some issues with it:
  1. "Dublicate pin name 25 exists in...." message during CAD export wizard in Library Expert.
  2. Short circuit violation on every pin in Altium during DRC check. "[Short-Circuit Constraint Violation] PCB.PcbDoc Advanced PCB Short-Circuit Constraint: Between Region (0 hole(s)) Top Layer And Pad IC?-10 (52.25 mm, 43.025 mm)  Top Layer Location : [X = 1121.95mm][Y = 648.925 mm]"
  3. Unable to apply "solder mask/paste expansion" rules to pads when footprint placed on PCB.
What is wrong with this part ?
Thanks a lot!
Post Options Post Options   Thanks (0) Thanks(0)   Quote toshas Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2017 at 12:38pm
2-3 solved!
Actually Altium does not support D-Shape pads. After replacement D-Shape to Oblong 2-3 are gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2017 at 12:42pm
There are duplicate Pin Names for the Thermal Pad Vias.
Altium can handle multiple pins with the same pin name.
If not, delete the via pad stack and resave the part.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2017 at 1:52pm
We updated the Texas Instruments part on POD to allow you to use your default pad shape in Preferences.
The part was converted from FP Designer to the Calculator for a better 3D STEP model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toshas Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2017 at 10:13pm
Thanks a lot!
Post Options Post Options   Thanks (0) Thanks(0)   Quote toshas Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2017 at 4:13am
Now I was able to export in Altium without any issues.
Thanks!
I'm working on prototype board and new footprint will be ok for it.
But other users may prefer old footprint (which was made exactly per datasheet recomendations: with thermal via and so on).
Is it possible to keep both ones in PCB Library ? Without direct replacement ?
Thanks again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2017 at 6:14am
The TI footprint that you originally downloaded was created in FP Designer.
If the part is created in the Calculator then anyone can apply their preferences for Solder Mask swell, Pad Shape, Paste Mask Reduction and use the mfr. recommended pattern.
You can also move the footprint from the Calculator to FP Designer to add the via matrix for the Thermal Pad.
Keeping the part in the Calculator will produce a better 3D STEP model.
This page was generated in 1.031 seconds.
