  New Posts New Posts RSS Feed - Transistor familiy for DFN 3 Pin?
jsutin View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote jsutin Quote  Post ReplyReply Direct Link To This Post Topic: Transistor familiy for DFN 3 Pin?
    Posted: 11 Mar 2013 at 11:29am
I would suggest adding transistor as a family for DFN 3 pin components.
Also, definitions for L1 and b1 seemed to be reversed, but this may be a judgement call especially since those dimensions entries do match the drawing below.
Thanks.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2013 at 11:49am
Thanks for the suggestion to add "Transistor" as a 3-pin DFN component family.
The "L" dimension is always the "Longest" dimension and the length of the Large Pin is rotated from the smaller pins. So L1 and b1 are correct.
Post Options Post Options   Thanks (1) Thanks(1)   Quote jsutin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2013 at 2:54pm
Thank you for explaining the convention.  In general, is there a push to standardize dimension nomenclature? Often, it seems manufacturers and cad software use completely different dimension names, even for fully defined JEDEC types.  It's a very minor hassle, but everything would be smoother if datasheets and calculators would agree. Does FPE follow any standards in this regard?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2013 at 6:01pm
PCB Footprint Expert strictly follows JEDEC dimensioning practices (just like most component manufacturer's also use JEDEC dimensions).
This page was generated in 0.343 seconds.
