Transistor familiy for DFN 3 Pin? |
jsutin
Joined: 09 Mar 2013 Location: Boston Status: Offline Points: 15 |
Thanks(1)
Topic: Transistor familiy for DFN 3 Pin?Posted: 11 Mar 2013 at 11:29am |
I would suggest adding transistor as a family for DFN 3 pin components. Also, definitions for L1 and b1 seemed to be reversed, but this may be a judgement call especially since those dimensions entries do match the drawing below. Thanks.
Thanks(1)
Posted: 11 Mar 2013 at 11:49am |
Thanks for the suggestion to add "Transistor" as a 3-pin DFN component family.
The "L" dimension is always the "Longest" dimension and the length of the Large Pin is rotated from the smaller pins. So L1 and b1 are correct. |
jsutin
Thanks(1)
Posted: 11 Mar 2013 at 2:54pm |
Thank you for explaining the convention. In general, is there a push to standardize dimension nomenclature? Often, it seems manufacturers and cad software use completely different dimension names, even for fully defined JEDEC types. It's a very minor hassle, but everything would be smoother if datasheets and calculators would agree. Does FPE follow any standards in this regard?
Posted: 11 Mar 2013 at 6:01pm |
PCB Footprint Expert strictly follows JEDEC dimensioning practices (just like most component manufacturer's also use JEDEC dimensions).
