  New Posts New Posts RSS Feed - 2013.05 Released!!
2013.05 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: 2013.05 Released!!
    Posted: 26 Jun 2013 at 4:49am
Version 2013.05 was just released!!
NEW:
  • Added an error message when the SOP body width is less than 3.0 mm
  • New 3D Component families added
    - Oscillator, J-Lead
    - Oscillator, L-Bend
    - Quad Flat No-Lead (QFN) with D-Shape Lead
    - Quad Flat No-Lead (QFN with Tab) with D-Shape Lead
    - Quad Flat No-Lead (QFN) with Rectangle Lead
    - Quad Flat No-Lead (QFN with Tab) with Rectangle Lead
    - Pullback Quad Flat No-Lead (PQFN) with D-Shape Lead
    - Pullback Quad Flat No-Lead (PQFN with Tab) with D-Shape Lead
    - Pullback Quad Flat No-Lead (PQFN) with Rectangle Lead
    - Pullback Quad Flat No-Lead (PQFN with Tab) with Rectangle Lead
    - Small Outline No-Lead (SON) with D-Shape Lead
    - Small Outline No-Lead (SON with Tab) with D-Shape Lead
    - Small Outline No-Lead (SON) with Rectangle Lead
    - Small Outline No-Lead (SON with Tab) with Rectangle Lead
    - Pullback Small Outline No-Lead (PSON) with D-Shape Lead
    - Pullback Small Outline No-Lead (PSON with Tab) with D-Shape Lead
    - Pullback Small Outline No-Lead (PSON) with Rectangle Lead
    - Pullback Small Outline No-Lead (PSON with Tab) with Rectangle Lead
 FIXED:
  • Chip Resistors now have black coloring, to differentiate them from capacitors
  • Environment characters (L, M, N) is now dropped from the STEP model name
  • OrCAD PCB – When performing a batch process, library name is no longer disabled4
  • 3D STEP – When performing a batch process, library name is disabled
  • Resolved isssue with definition of 'Mechanical Pins'
  • Orientation of D-Shaped pads now functions as expected
  • Changed Padstack Height to Y and Width to X
  • Allow user to define pin locations in Properties
