  New Posts New Posts RSS Feed - Batch-Build Preferences
dwaltoneng View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwaltoneng Quote  Post ReplyReply Direct Link To This Post Topic: Batch-Build Preferences
    Posted: 20 Jun 2013 at 11:45pm
When you build a library, should the options in the "Batch-Build Preferences" dialog box override the settings in "Setup->User Preferences->Design"?
If in "Batch-Build Preferences" I select Environment=User and clear the "*User name suffix", the components still end up with the suffix USR.
If I clear "Setup->User Preferences->Design->*User name suffix", the suffix is not added.
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2013 at 6:13am
I am not using the USR settings in batch mode but "N" mode.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2013 at 6:19am
If you're using the "Nominal" environment, did you create your own "MyDefaultPreferences.dat" file?
Or are you using the out of the box "DefaultPerferences.dat" IPC-7351C file that comes with the installer?
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2013 at 6:25am
Yes, I created my own My own mydefaultpreferences.dat file.
I also create my own decal name since the default name does not contain enough information for me personally.
I add the "N" at the end of the name when I create a "N" decal so it saves that decal name in PADS and then in my FPX library.
This page was generated in 0.719 seconds.
