  New Posts New Posts RSS Feed - Step File Output and PADS Layout
plinder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plinder Quote  Post ReplyReply Direct Link To This Post Topic: Step File Output and PADS Layout
    Posted: 10 Jun 2013 at 5:01am
We are interested in the new 3D feature (generating step outputs).  We use PADs, and we have exported a couple of boards to 3D for use with Solid Works.  How would we cause the 3D step models of the parts to become a part of that 3D export from PADs?
In general, we have found the PADs 3D export to be dificult - for example, we have had a difficult time getting holes to appear in the export.  So, I won't be surprised if PADs can not really take advantage of these step files - but I'm positive someone knows better than me!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2013 at 12:04pm
The PCB Library Expert (LE) saves component dimenions to FPX files. You can't see them (unless you open the FPX file in M/S Excel column B) but they are there.
The 3D STEP module auto-generates 3D STEP models from FPX file data.
Soon we will have FPX files for millions on component manufacturer part numbers on our new "Parts on Demand" (POD) website.
ashwini.uthotakaa.com View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ashwini.uthotakaa.com Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2014 at 10:00pm
Dear Friend.
I am using PADS Layout V9.2 (Mentor Graphics).
I want to export a PCB file in 3D format.
Can anybody suggest me the procedure to export a PCB file in 3D format, and that 3D file I have to view in 3D Viewer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2014 at 9:32am
Hi Ashwini,
I'm not familiar enough with PADS to know if it has a 3D Export function for boards. Most tools allow you to view stuff in 3D using a built-in viewer, not necessarily convert the entire board to a 3D format. Currently we work with generating 3D models for the components we calculate, we don't work with entire boards in that manner.
-Chris
This page was generated in 0.688 seconds.
