  New Posts New Posts RSS Feed - 2013.03 Released!
2013.03 Released!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: 2013.03 Released!
    Posted: 07 Jun 2013 at 12:02pm
Version 2013.03 was just released!!
NEW:
  • 3D Expert – Auto-generate 3D STEP models for FPX component dimensions and supports these component families
    1. Aluminum Electrolytic Capacitors (CAPAE)
    2. BGA (Ball Grid Array)
    3. CGA (Column Grid Array)
    4. Crystal
    5. LGA (Land Grid Array) with Round Lead
    6. LGA (Land Grid Array) with Square Lead
    7. QFP (Quad Flat Pack)
    8. QFP (Quad Flat Pack) with Thermal Tab
    9. CQFP (Ceramic Quad Flat Pack)
    10. Oscillator, Corner Concave
    11. Oscillator, Side Concave
    12. PQFN (Pullback Quad Flat Pack) with D-Shape Leads
    13. PQFN (Pullback Quad Flat Pack) with Rectangle Leads
    14. PQFN (Pullback Quad Flat Pack) with D-Shape Leads and Thermal Tab
    15. PQFN (Pullback Quad Flat Pack) with Rectangle Leads and Thermal Tab
    16. SOD
    17. SODFL
    18. SOIC (Small Outline IC)
    19. SOIC (Small Outline IC) with Thermal Tab
    20. SOP (Small Outline Package)
    21. SOP (Small Outline Package) with Thermal Tab
    22. SOTFL
    23. CFP (Ceramic Flat Pack)
    24. SOD (Small Outline Diode)
    25. Crystal, Surface Mount
 FIXED:
  • Allegro – Preventing cells from properly converting from inches and microns to mils and millimeters, respectively
  • Expedition –  ASCII output that was erroneously adding blank outlines
  • Expedition – Fixed issues dealing with Padstack Through-hole output
  • CADSTAR – Alignment for text has been set to CENTERCENTER
  • PADS - Older versions were having trouble with rounded corners
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2013 at 12:39pm
To get the 3D STEP license at introductory pricing, go here! We have lots of happy customers from last year who got in early on the Library Expert at a very low cost. Here's your chance to get in on the 3D STEP at the lowest point possible - for the next month or so only.
Free updates to all 2013 releases and pathway to upgrade to v2014 next year at 30% the cost!
