  New Posts New Posts RSS Feed - Older Preferences and FPX Library with 2013
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Topic: Older Preferences and FPX Library with 2013
    Posted: 29 May 2013 at 5:15pm
Why does 2013.02 load in a new directory so I have to reset my defaults and libraries?
Is there any easy way to reuse my previous settings and libraries?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2013 at 6:01pm
You should copy/paste all of your library files to the new folder.
Or you can set your Library Path in "Setup > User Preferences > Files > Library Directory"
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2013 at 3:12pm
I just tried that , reloaded the program and although is says the old directory name in the Setup options. When you go to the library it is still selects the 2013 directory.
