  New Posts New Posts RSS Feed - 2013.02 Released!!
2013.02 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: 2013.02 Released!!
    Posted: 23 May 2013 at 1:16pm
Version 2013.02 was just released!!
NEW:
  • Footprint Designer for non-standard packages
  • DesignSpark – Made significant improvements to the DesignSpark ASCII
  • OrCAD PCB/Allegro – The ability to generate more than one Part Per Script File. This greatly enhances batch create
  • OrCAD PCB/Allegro – The ability to generate the files to a Library Name of your choosing. If someone is making single parts, they can dump them into say the MyParts directory. By having MyParts in the path, they can build them out of that directory rather than just the normal User Directory. Previously.. a single part had created its own directory with the same name and you either had to copy the files to the user directory for build, build a batch, or put each new part directory in the Path.
  • Support for CADint
FIXED:
  • Expedition ASCII Rotation has been fixed to not include quotes around the Rotation
  • Expedition ASCII Circle Shapes will no longer inadvertently include the Width parameter of Circle Paths
  • Pulsonix – Made sure a rogue UI element went away
  • CADSTAR – Origin not being applied for poly drafting elements
  • P-CAD – adjusted default layer mappings
