  New Posts New Posts RSS Feed - Numeric Pin Names on Diode
Lekselius View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lekselius Quote  Post ReplyReply Direct Link To This Post Topic: Numeric Pin Names on Diode
    Posted: 22 May 2013 at 1:37am
I'm trying to rename the Pins on a diode from C/A to 1/2 in a molded body using "Right click" -> "Properties" but when changing to a numeric value I get the message "Use 'Pin Reorder' to generate numeric pin names". However 'Pin Reorder' is not available when I right click on the pin. (It comes up fine with e.g. SOT23).
A workaround is to set the family to "polarized capacitor" but I would like to have the pin names to 1 and 2 for the diodes as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2013 at 12:42pm
You need to "Right Mouse Click" on the pads.
If the Pad has an Alphabetical name this will appear -
If the pad has Numeric pin assignment, this will appear -
