  New Posts New Posts RSS Feed - Standard Header
Standard Header
AGONZ67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AGONZ67 Quote  Post ReplyReply Direct Link To This Post Topic: Standard Header
    Posted: 25 Mar 2013 at 5:42pm
Is there a true definition for a "standard header"? I have heard the term used through the years but is a standard header truly a defined part? I did a quick search of various headers and found different lead sizes & shapes. For example PADS library calls out HDR16, HDR18 etc, with several different sizes of holes. Header datasheets from different manufacturers had square, round, .40-.67 mm pins in the few that I checked. So is there a true "standard header" or is this an antiquated term carried over?
Post Options Post Options   Thanks (2) Thanks(2)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2013 at 8:12pm
The standard header has a 0.25" square pin on 2.54 mm (0.10") pin pitch.
The new 2.0 mm pitch is trying hard to replace it.
zetex17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zetex17 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2013 at 7:25am
In fact, the pin size of the standard header is 0.025" or 0.64 mm
