  New Posts New Posts RSS Feed - Footprint Calculator
BryanT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BryanT Quote  Post ReplyReply Direct Link To This Post Topic: Footprint Calculator
    Posted: 20 Mar 2013 at 9:05am
Hi Tom, I tried using FPE and saw that in the footprint tab it did not show dimensions for pads, outlines, etc.  So you cant use FPE like the old LP Wizard Calculator?
Bryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2013 at 9:44am
We allow querying of each specific dimension by using the viewer. Select the layer which has the object you want to query (for example if you want Silkscreen, select the Silkscreen layer), then "Right-Click" and select from the options available to see the dimensions. This method allows you to get much more data than was provided before in the LP Wizard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2013 at 12:20pm
The new PCB Footprint Expert has many more features than the LP Wizard.
The Footprint Tab allows the user to enter the component mfr. recommended pad size and space.
Like Nick mentioned you can now select Lines or Shapes, Text, Pads and RMB Query. This provides the layer, line width, pad size, padstack name and you can change the Pin Name in most component families from Numeric to Alpha-numeric or visa-versa.
We realize that the program needs a "Help" menu and some training videos which are in production right now.
Post Options Post Options   Thanks (1) Thanks(1)   Quote BryanT Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2013 at 10:54am
Not sure if I've asked this before but is there a way to print out a "datasheet" of a newly created part (or any part really) like we were able to do in the LP Wizard?  That is a good way of sharing info with others.
Bryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2013 at 11:03am
We're currently focused on developing support for 3D and allowing users to create footprints for non-standard parts (effectively doubling the capacity of the LP Wizard!!). The support for non-standard parts will be available in v2013 with the Package Designer module. Once things stabilize, we will look at a print feature for it all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BryanT Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2013 at 11:19am
Ok great - thanks Nick!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2013 at 12:17pm
Yes, the print feature works great for "Standard" packages but today only 50% of the component packages are Standard.
I do think that some day there will be some kind of dimensioned image for the Component and Footprint, but we need to prioritize the workload on automation for non-standard packages and 3D modeling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2013 at 1:47am
Please review the comparison between the LP Wizard and PCB Library Expert -
This comparison list offers a good side-by-side list comparison of the major features and benefits of each...
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2013 at 3:40pm
Is anyone still interested in the "Print Datasheet" feature for PCB Library Expert dimensions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Artwork Master ITALY Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2013 at 4:24pm
yes i am.
