  New Posts New Posts RSS Feed - Some Simple UI Stuff
 Rating: Topic Rating: 3 Votes, Average 4.67  Topic Search Topic Search  Topic Options Topic Options
DaveCowl View Drop Down
Post Options Post Options   Thanks (2) Thanks(2)   Quote DaveCowl Quote  Post ReplyReply Direct Link To This Post Topic: Some Simple UI Stuff
    Posted: 18 Mar 2013 at 1:33pm
When we try to exit with unsaved data, can we please have an option to 'Save and Exit' rather than just 'OK' and 'Cancel'?
Also, can Ctrl + F please be linked to the "Find" function as a shortcut? It is so natural to Ctrl-F to do a Find in the Library and I am always just a little disappointed when it does nothing...
Also, Ctrl + S = save FPX
Cheers!
reinerwie View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote reinerwie Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2013 at 11:50pm
Originally posted by DaveCowl DaveCowl wrote:
When we try to exit with unsaved data, can we please have an option to 'Save and Exit' rather than just 'ok' and 'cancel'?
Also, can Ctrl-F please be linked to the Find function as a shortcut? It is so natural to Ctrl-F to do a Find in the Library and I am always just a little disappointed when it does nothing...
Cheers!
dannicholson View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote dannicholson Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2014 at 2:59am
I agree. I just lost a bunch of work because I forgot to save before closing the program. It should prompt you to save the library if there are changes. Or an option for autosave every few minutes maybe?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2014 at 3:21am
Sorry to hear that! This suggestion has been forwarded to Jeff who is in charge of development.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2014 at 11:41am
V2014.05 fixes the problem with closing the program and not prompting you of unsaved data. If you make any edits to a FPX file, a dialog box will appear warning that you have unsaved edits and allow you to abort the exit and return to the FPX file or continue to close the program.
We also added -
  1. Double Click on any feature opens "Properties" dialog window
  2. When in a Properties dialog window, keyboard "Enter" toggles the cursor to the next field and closes and saves the data if cursor is in the last field.
