  New Posts New Posts RSS Feed - Query Environment at the End of BGA Footprint Name
jameshead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Topic: Query Environment at the End of BGA Footprint Name
    Posted: 14 Mar 2013 at 4:29am
Not sure what the intention is for footprints of BGAs but I was under the impression there is (or was) no environment for BGAs and this is indicated in in the "FOOTPRINT NAMING CONVENTION" for Standard SM Components" PDF.
Ball Grid Array’s ......................................................................... BGA + Pin Qty + C or N + Pitch P + Ball Columns X Ball Rows _ Body Length X Body Width X Height
The Create Footprint dialogue adds an environment letter at the end of the footprint name though which I wasn't expecting to see.
I know the copper pad has no difference between environments but depending upon what the user has picked for courtyard, silkscreen line width, RefDes height etc. this could be applicable if this is the intention.
Also, is that an errant apostrophe in Array's?  I'm not sure if the Arrays own the balls but my English isn't great.  I lent my copy of Eats Shoots and Leaves to a Scouser so it's little wonder I didn't get it back LOL.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2013 at 7:02am
IPC-7351C introduces a new 3-Tier library system for all parts because of Drafting items and Local Fiducial sizes.
Example:
Silkscreen Outline for Most = 0.15 mm
Silkscreen Outline for Nominal = 0.12 mm
Silkscreen Outline for Least = 0.1 mm
Ref Des and Local Fiducials are also 3-Tiers.
So you can now hace a BGA in the Most environment and the pad size is the same for all 3 environments but everything else is 3-Tiers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2013 at 7:14am
Thanks.
Naveed Khan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Naveed Khan Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2013 at 2:37am
Hi Jameshead,
Is it because of BGA's are categorized as collapsing and non-collapsing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2013 at 6:59am
3-Tiers on BGA's only affect these items in the library parts -
  1. Silkscreen Line Widths
  2. Reference Designator Heights
  3. Local Fiducial Sizes
3-Tiers on BGA library parts do not affect these items -
  1. Pad Sizes
  2. Placement Courtyard Excess
  3. Assembly Outline Line Width
  4. Collapsing or Non-collapsing Ball
  5. 3D Model Outline
This page was generated in 1.488 seconds.
