  New Posts New Posts RSS Feed - Method For Saving Non-default Values
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Topic: Method For Saving Non-default Values
    Posted: 08 Mar 2013 at 8:18am
There are many additional values that can be changed in creating footprints other then the dimensions. These other values are used to create the current footprint but are not saved to the library when you save the footprint to the library. It would be nice if either you could save any of these changes to the library or when you save the footprint to the library a message comes up stating that the updated values will not be saved to the library.
This page was generated in 0.735 seconds.
