  New Posts New Posts RSS Feed - Lead Width on Axial Through Hole
jameshead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Topic: Lead Width on Axial Through Hole
    Posted: 07 Mar 2013 at 2:40am
The PDF for IPC-7251 states:
W = Maximum Lead Width (or Component Lead Diameter)
In Through Hole > Axial though users have to enter both Min and Max values for b and the calculated footprint name uses the nominal value for b, for W, and not Maximum Lead Width as I expected.
IPC-2222 says "no greater than 0.7 mm (level A) over minimum lead diameter" so I guess that's why FPX has a mandatory field for a Min value for b in Axial (?) but if I'm creating a footprint in a program like FPX I am more concerned with the maximum lead diameter and the "No less than 0.25 mm over maxium lead diameter".
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2013 at 9:11am
A maximum value is required to calculate the hole.
A minimum value is required to get the nominal value which is used in the footprint name.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2013 at 9:14am
Hi Jeff, thanks for the reply.
My observation is that the PDF guide for IPC-7251 says:
So, W should be taking the maximum and not the nominal dimension.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2013 at 7:33am
This behavour in FPX hasn't changed in the v47 Beta today.
The PDF guide for IPC-7251 naming says:
Diodes, Axial Diameter Horizontal Mounting .......................................DIOAD + Lead Spacing + W Lead Width + L Body Length + D Body Diameter
Example: DIOAD800W52L600D150B
Diodes, Non Polarized Axial Diameter; Lead Spacing 8.00; Lead Width 0.52; Body Length 6.00; Body Diameter 1.50
And on page 3:
The way I read this was that W is always the Maximum whether it's the lead width or component lead diameter, but Jeff's saying W is nominal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2013 at 8:24pm
The Calculator requires Maximum to determine the hole size per IPC-7251 (which is currently on the table by IPC for review for release (finally)).
The component dimensions require the Minimum so the Calculator can determine the value for the Footprint name. Every value in the Footprint Name is a "Nominal" component package dimension with one exception - "Height"
Naveed Khan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Naveed Khan Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2013 at 1:52am
How to calculate pitch for axial lead components? IF mounted horizontally and vertically?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2013 at 6:27am
The PCB Footprint Expert has a "Utilities" button in the Main Toolbar. Select the "Axial Leadform Calculator" option and this menu will appear -
I hope this helps...
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2013 at 8:41am
I understand but I think the PDF for the PCB Libraries Footprint Naming Convention for Standard TH Components on page 3 confuses users since it says:
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2013 at 12:31pm
I agree that we need to clarify Wmax for hole calculation and Wnom for Footprint Name.
