  New Posts New Posts RSS Feed - Automatically generate 3D bodies in Altium
Joris View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Joris Quote  Post ReplyReply Direct Link To This Post Topic: Automatically generate 3D bodies in Altium
    Posted: 04 Mar 2013 at 8:49am
Hi All,
I've created an Altium script that automatically generates 3D bodies based on the 3D outline as exported by FPE, and the height in the IPC filename.
Although they are a little simpler I strongly prefer this over step files, since they are much lighter to handle (especially for big boards).
I'm releasing it here under Attribution-ShareAlike 3.0 United States:
http://creativecommons.org/licenses/by-sa/3.0/us/
Everything is provided as-is and is not affiliated with PCB Libraries in any way.
Download:
Instructions:
- Build and Import your library as you would normally do.
- Make sure the attached FPETools is opened in Altium
- Open up the newly created Lbrary
- Click DXP -> Run Script -> CreateBodyFromOutline
- Save the library
Best regards,
Joris
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2013 at 10:36pm
Thanks, Joris.
We're currently working on a more advanced 3D translator to STEP. An initial version (BGA only) is planned for release with version 2013, and the remainder of the component families over the course of the next several months.
Nick
craigcu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote craigcu Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2013 at 9:29am
Hi Joris,
I believe many Altium users would be pleased if you could share your script at:
https://code.google.com/p/altium-designer-addons
Craig, AMTELCO
cRAIG, amtelco
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2013 at 9:35am
Regardless what Joris says, can you mention the 3D STEP outputBig smile
There is no need to purchase the software to create the BGAs.
