  New Posts New Posts RSS Feed - 2012.43 Released!
2012.43 Released!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: 2012.43 Released!
    Posted: 11 Feb 2013 at 1:28pm
Version 2012.43 has just been released!
FIXED:
  • OrCAD PCB/Allegro – Fixed an issue with hidden pins not being filtered
  • PADS – Fixed Thermal Pad orientation when chamfered corners were used
  • PADS – When ‘Map Alphanumeric pins’ is unchecked, the alphanumeric pins will properly be moved from the Part-Type to the Decal
  • PADS – When extended layers is selected and a part type/decal is output, the extended layer selection will now be properly recognized
  • PADS – Fixed a problem that was causing through-hole anti-pads generated at half their size
  • Ultiboard – Added a &ASC; to the LandPatternName so that they import properly
  • Ultiboard – Set the visibility of the pin attribute to ‘2’ to match what had been done in the past
  • TARGET 3001! – Pins now properly have pads set to layer 2 instead of layer 100
  • Calculator – Header’s switching for millimeter to inch units
  • Calculator – Thermal Pad dimensions being swapped
This page was generated in 0.189 seconds.
