  New Posts New Posts RSS Feed - 2012.42 Released!
2012.42 Released!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: 2012.42 Released!
    Posted: 02 Feb 2013 at 1:45pm
Version 2012.42 has just been released!
FIXED:
  • PADS – Added the flag field to the header line for all versions of V2007 and V9 Part Types
  • Board Station – Default padstack not being called out
  • Allegro – Removed the “Fillin Yes” for padstacks when changing units
  • EAGLE – Polygons with 0 line width will now have a minimum line width of .01 mm
  • EAGLE – Text font line widths
  • EAGLE – The Description line for a library has been removed
  • EAGLE – ‘PCB Libraries Packages’ will be appended to each individual part description
  • Expedition – Complex pads not exporting to ASCII
  • Expedition – Altered the ASCII output of the vertex array for complex pads and outlines to match how direct import generates them, including Arcs
  • Calculator – Corner Concave Oscillators, Mfr. Recommended Footprint was rotating the component leads 90°
  • Calculator – 3-pin DFN Mfr. Recommended Footprint for large pin
  • User Preferences – Through-hole Headers, Oscillator and TO Cylindrical settings not saved
NEW:
  • Support for TARGET 3001!
  • Support for McCAD
  • Support for Board Station
  • Default Preferences Window - Added a box around the “File” dropdown for better visibility
