  New Posts New Posts RSS Feed - Categories - Resorting Column Data
 Rating: Topic Rating: 10 Votes, Average 4.60  Topic Search Topic Search  Topic Options Topic Options
ootbRobo View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ootbRobo Quote  Post ReplyReply Direct Link To This Post Topic: Categories - Resorting Column Data
    Posted: 27 Jan 2013 at 10:29pm
When sorting a library via categories it is impossible to sort using any of the library columns.
Clicking any of the columns for sorting by name etc. will undo the category filter.
Evenkeel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Evenkeel Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2013 at 2:15pm
This would be high on my 'desired' feature list as well.
Categories are helpful but still need column sorting as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2013 at 2:30pm
I see a lot of these great features, but no one is rating them.
Please use the rating system to rate each feature 1 - 5 stars.
The more people who rate the higher the rating gets and the faster the feature gets implimented.
I'm going to rate this 4-stars, but everyone needs to rate it too. Not just 1 person. The more the better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Evenkeel Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2013 at 3:21pm
If 5 is a GOT TO HAVE IT and a 1 is a IF YOU NOTHING BETTER TO DO, then I would certainly rate this as a 4.5
Post Options Post Options   Thanks (1) Thanks(1)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2013 at 3:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Evenkeel Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2013 at 3:52pm
Embarrassed  Whoops!  Thanks ... that helps (and is easy!)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2014 at 1:01pm
The "Categories" feature works on the location of a Semi-colon and "Physical Description" is the only attribute with a Semi-colon.
Capacitor, Polarized, Molded Body ; 7.30 mm L X 4.30 mm W X 3.10 mm H body
In Categories, the Semi-colon is normally placed before the component dimensions. In this example, Capacitor, Polarized, Molded Body would show up in the list.
You can create your own "Physical Description" and locate the Semi-colon anywhere you want.
This page was generated in 0.218 seconds.
