  New Posts New Posts RSS Feed - 2012.41 Released!
2012.41 Released!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: 2012.41 Released!
    Posted: 27 Jan 2013 at 6:29am
Version 2012.41 has just been released!
FIXED:
  • All PADS variants – Text items dealing with units
  • All PADS variants – Outputting older versions of PADS
  • Allegro – Mapping of microns to millimeters and inches to mils
  • Expedition – Changed “Batch Create” to process from first row in FPX list
  • Expedition – Creating parts with singular silkscreen lines
  • FPX Library Editor – Copy/Paste rows from an existing FPX file into a “new” FPX file
  • FPX Library Editor – Adding a new column attribute “Datasheet” the links did not work until the FPX file was closed and reopened
  • Renamed stock FPX files to IPCBGA, IPCSM and IPCTH in the IPC folder
Note: you must manually delete BGA, SM and TH FPX files in the IPC folder or archive them
