  New Posts New Posts RSS Feed - 2012.40 Released!
2012.40 Released!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: 2012.40 Released!
    Posted: 19 Jan 2013 at 2:27pm
Version 2012.40 has just been released!
FIXED:
  • Library Editor – Problem with importing one FPX into another with different column attributes
  • Library Editor – Updated the “Physical Description” for PTH Headers, DIP, SIP, OSC and SMT Side Concave Diodes
  • Shrouded Headers – Footprint Name
  • PADS (all variants) – Fixed a problem with the linestyle in ASCII export
  • Allegro – All through-hole padstacks will now be set to have a cross as a drill symbol
  • Allegro – Modified the complex pad naming convention for rounded pads to include length, height, and cornerlength
  • Allegro – Added some SKILL commands
  • Expedition – Pre-existing Padstacks, Pads, and Holes will no longer be deleted in the target database; instead, if one is preexisting, it will use what is already there
  • FPE FPX – Customer FPX file added 330 Intersil and 82 Micochip packages, checked and fixed all web-links, now contains 4,953 packages
This page was generated in 0.688 seconds.
