  New Posts New Posts RSS Feed - How Do I Export to Allegro?
JohnV2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnV2 Quote  Post ReplyReply Direct Link To This Post Topic: How Do I Export to Allegro?
    Posted: 09 Jan 2013 at 5:28am
I am a first time user and need to know where to setup Allegro output. Advise?
Post Options Post Options   Thanks (2) Thanks(2)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2013 at 8:46am
Select any component family and enter the component dimensions.
Then select the last icon in the toolbar (the Wrench).
That will open the CAD Translator window.
Use the CAD tool dropdown and select Allegro.
Also select "Set as Default Format"
Then select the folder in which you want to save the PCB library files.
Then select your Allegro options.
Then select "Save Entries as Preferences" so that every time you come back to this window all of your settings will be the same.
Let us know if this works.
The User Guide is here -
