  New Posts New Posts RSS Feed - Limitation In Numeric Entry?
Evenkeel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Evenkeel Quote  Post ReplyReply Direct Link To This Post Topic: Limitation In Numeric Entry?
    Posted: 27 Dec 2012 at 10:04pm
Given the internal 1/100 mic scale, why does FPX prevent the entry of a number less than 0.001 mm?
Specifically, if I try to set my 3D Model Outline Width to something less than 0.001 mm (1 mic, right?) the tool doesn't permit it.
Why would I want something so small Big smile?
Well, Eagle has a ULP that will use the body outline data line _width_ to represent the body _height_ and generate the proper IDF model for importing into Solidworks (or so the story goes).  So, I would like to build my part libraries to accommodate this capability (at least until there is real 3D support from Cadsoft).
I can (and do) edit the resulting Eagle export to change the associated layer's line width before I import it into Eagle.  However, it would be 'nice' to be able to use the tool's 3D Outline feature to do the work for me :-)
