Forum Home Forum Home > Libraries > Schematic Symbols > CADSTAR
  New Posts New Posts RSS Feed - Create Pin List (CSV)
frape View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frape Quote  Post ReplyReply Direct Link To This Post Topic: Create Pin List (CSV)
    Posted: 21 Dec 2012 at 2:06am
Hi forum users,
when I create a new schematic symbol for a MCU using the block wizard I have to spend a lot of time in order to write on my own the pin labels. Sometimes the number of pins is about 100. I have seen that Cadstar gives the opportunity to import a pin list written in a csv format but I cannot find an example.
Does somebody know how this csv file should be written?
Thanks in advance for your help!!!
Mattylad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattylad Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2012 at 5:25pm
In the help search for
Aldec .csv Information
If you cannot figure it out from that post back and I'll find an example file when I return to work in the new year.
By having a good pin list it allows you to import all the gates, pins, pin side - pin labels etc into your symbols within the block wizard, which then allows you to output a multigate file which can be imported during part creation to fill in all the pin mapping and labels.
This enabled me to make a 1760 pin BGA part with about 40 symbols in under 30 minutes Big smile
Took a heck of a lot longer to check and validate it all.
This page was generated in 0.609 seconds.
