  New Posts New Posts RSS Feed - GPS-PA6B
GPS-PA6B
hakaday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hakaday Quote  Post ReplyReply Direct Link To This Post Topic: GPS-PA6B
    Posted: 08 Dec 2012 at 2:39am
Hi all
I haven't done any PCB related work for about 10 years. I would like to layout a GPS board based on the PA6B GPS module from GTop and do it once with the correct footprints.
How does one define a custom component or which footprint should one use to start a footprint for this device.
I'm using the freeware version for the moment.
The datasheet for the device is located here:
http://www.gtop-tech.com/en/product/GPS_Modules_PA6B.html
Thanks for your help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2012 at 8:13am
You need a little more information than the datasheet provides.
You need the physical component dimensions and/or the manufacturer recommended footprint dimensions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hakaday Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2012 at 9:12am
Thanks for the reply Tom.
The linked document is unfortunately all I have to work with. But I believe all the relevant data is in the datasheet.
Steven
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2012 at 9:18am
Not enough data to create the PCB library part.
Post Options Post Options   Thanks (1) Thanks(1)   Quote hakaday Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2012 at 9:49am
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2012 at 10:40am
Using the current PCB Footprint Expert, I built this library part in less than 2 minutes using the component manufacturer's recommended solder pattern.
First I inserted the component dimensions and removed the deleted pins -
Then I selected the "Footprint" tab and inserted the component manufacturer's recommended solder pattern dimensions -
Then I selected the CAD tool of my choice and select the "Create" button - Bam!
Post Options Post Options   Thanks (0) Thanks(0)   Quote hakaday Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2012 at 11:05am
Thanks Tom
Part of the problem was, I did not know which component to use the start the definition.
The other problem that I had (have) is deletion of the pins. (I will follow the tutorial again.)
I also tried to create the hole for the antenna which did not work to well.
I will follow your example.
Your help is much appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2012 at 11:35am
I used the SON (Small Outline No-lead) component family because it has the "Delete Pin" feature to remove the missing pins.
