  New Posts New Posts RSS Feed - IPC-2581 & Graphicode
jameshead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Topic: IPC-2581 & Graphicode
    Posted: 29 Nov 2012 at 5:30am
GC Prevue has a SAVE AS IPC-2581 option, as below, but I haven't had any success using it.
The resultant XML file cannot be read by WiseView nor Vu2581, my two viewers.  It appears to be a binary format file rather then the ascii that I've been advised should be present.
I've been told that the format of a correct file should be:
<?xml version = "1.0" encoding = "UTF-8"?>
<IPC-2581 xmlns="http://webstds.ipc.org/2581" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
  <Content>
    <FunctionMode mode="FULL" level="1"/>
    <StepRef>PCB</StepRef>
    <LayerRef>BOTTOM</LayerRef>
    <LayerRef>TOP</LayerRef>
    <LayerRef>L7</LayerRef>
    <LayerRef>L6</LayerRef>
    <LayerRef>L5</LayerRef>
    <LayerRef>DRILLPADS</LayerRef>
    <LayerRef>L4</LayerRef>
    <LayerRef>L3</LayerRef>
    <LayerRef>L2</LayerRef>
    <LayerRef>R2</LayerRef>
    <LayerRef>R1</LayerRef>
    <LayerRef>DRILL_1-9</LayerRef>
    <LayerRef>P2</LayerRef>
    <LayerRef>M2</LayerRef>
    <LayerRef>outline</LayerRef>
    <BomRef>AllBOM</BomRef>
    <DictionaryStandard units="MILLIMETER">
GCPrevue will open it okay, not unsurprisingly, but WiseView displays the error:
I appreciate this is a very new standard that's still being developed.  The only sample files I have at the .cvg format ones, not .xml so wasn't entirely sure if there'd be a difference in the two different formats.
Has anybody used the GC Prevue IPC-2581 output sucessfully in something else?
My current theory is that they've put it in there only as a test at this stage and hoped no one would start to play around with it and that they've encoded it so only GC Prevue can open it before they release it officially.
This page was generated in 0.283 seconds.
