  New Posts New Posts RSS Feed - 2012.32 Released!
2012.32 Released!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: 2012.32 Released!
    Posted: 26 Nov 2012 at 2:28pm
Version 2012.32 has just been released!
FIXED:
  • Proportional Fab Level settings are not correct (major fix)
  • Pin Grid Array delete/restore pins
  • Physical Description for gullwing and J-lead parts “body width” dimension was changed from “Lead Span” to “Package Body”
  • Physical Description 4 side part pins, Body Length and Width were swapped
    - SAMPLE, SM and FPE .fpx files were updated
  • Radial Description not correct for round body styles
  • TH terminal description not displaying correctly for <=0.4 or > 0.4 lead sizes
  • Hole on assembly setting is not displaying in calculator terminal settings, user settings or default settings
  • DIP/SIP description is displaying 'plastic'  instead of 'package'
  • Reduced pin name size in the footprint display for Grid Array Patterns to eliminate overlapping text
  • Flange Mount (TO-220) Horizontal picture graphic and dimensional reference entries changed to reflect typical datasheets
NEW:
  • Network License now availabile (using SafeNet)
  • CPU utilization enhanced to significantly speed up loading time
This page was generated in 1.266 seconds.
