  New Posts New Posts RSS Feed - 2012.31 Released!
2012.31 Released!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: 2012.31 Released!
    Posted: 20 Nov 2012 at 8:50am
Version 2012.31 has just been released!
FIXED:
  • PADS V9.5 – ASCII code issues
  • Allegro – Fixed a problem with generating parts with square pads, usually a problem with through-hole parts
  • P-CAD – Fixed an issue causing the units to be converted twice, which placed all the pads at very small values (essentially 0, 0)
  • Calculator – Problem with E2 dimension units conversion from Inches to Millimeters
  • Calculator – Right Angle Header producing wrong footprint name
  • Calculator – Flange Mount (TO) producing wrong footprint name and Physical Description
  • Calculator – Fixed a math issue for Proportional Through-hole padstacks for Square Pad shape
  • Preferences – 2-sided part footprint names not reflecting user naming unit preference
  • Graphic Viewer – Changed the pin name text font size to 2/3 pad width to prevent overlapping text
  • Vertical Headers created in Batch Mode with incorrect outlines
NEW:
  • Added support for CR-5000
  • Added "Rounded Rectangular" shape option to SOD & DPAK
