  New Posts New Posts RSS Feed - Mismatch Between Options and HKP Data
DaveCowl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCowl Quote  Post ReplyReply Direct Link To This Post Topic: Mismatch Between Options and HKP Data
    Posted: 06 Nov 2012 at 1:25pm
I am seeing a mismatch between the text height options and the output in the HKP files.
The settings in the tool are what I would expect based on the slides from the presentation.
Line width .12mm, SS height 1.2mm and Assembly 0.5-2.0mm.
However the HKPs simply are 1.5mm and .15mm linewidth.
It is possible that something isn't linked right in my setup or these parameters may not be making it to the output due to a software bug?
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2012 at 2:12pm
As it currently stands, we don’t store text designator or text part type information.
It's built to base defaults in the target tool itself upon translation and the user is expected to do what they will with the text post-translation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCowl Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2012 at 2:37pm
I don't really see the point of having these drafting settings if they don't make it into the file export...?!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2013 at 11:24am
The Drafting Settings are your "User Preferences".
Only the Physical Package Dimensions are stored in the FPX file.
The way the PCB Library Expert works is - When the component dimensions and the user rules come together a footprint is created.
User Rules change all the time, but package dimensions never change.
