  New Posts New Posts RSS Feed - Electrical type
Electrical type
androjes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote androjes Quote  Post ReplyReply Direct Link To This Post Topic: Electrical type
    Posted: 05 Nov 2012 at 9:31am
Does anyone know the meaning/difference between all electrical type in Altium:
- open collector
- passive
- open emitter
- HZ
And when to use them?
ruffy91 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ruffy91 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2013 at 11:18pm
It is used for Electrical Rule Checking.
In the schematic look at "Project" -> "Project Options.." then go to "Connection Matrix".
There you can define different error levels for every connection type.
For example generate a warning if you connect an output pin to an open collector pin.
This page was generated in 0.520 seconds.
