  New Posts New Posts RSS Feed - 2012.29 Released!
2012.29 Released!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: 2012.29 Released!
    Posted: 04 Nov 2012 at 7:13am
Version 2012.29 has just been released!
FIXED:
  • Setting QFN Pins E to "1" throws exception
  • Thermal Pad corner chamfer and radius not getting added to padstack name
  • Pitch value not automatically adding leading and trailing zeros
  • Thermal Tab associates with wrong pin when signal pins are hidden
  • New row is added at top after library is sorted
  • Mil Unit conversion not importing to library correctly with all features in 1 mil increments
NEW:
  • Added Pin Grid Array (PGA) component family
  • Added 4 - 16 pins to 4 side Chip Array
  • Added non-polarized Diode to Chip and Molded families for Bi-directional Diodes
  • Removed condition where tab switches to component after each calculation
  • Changed Place Round definitions to be half of previous values but doubled them where required to create pad and line locations that fall on the round-off
  • Switched to Net Framework 4.0
This page was generated in 0.329 seconds.
