  New Posts New Posts RSS Feed - Chip Array, 4 Side Flat only has 10pin
rickdehart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickdehart Quote  Post ReplyReply Direct Link To This Post Topic: Chip Array, 4 Side Flat only has 10pin
    Posted: 30 Oct 2012 at 4:49pm
I noticed the Chip Array, 4 Side Flat only has the capability of 10pins.  Would it be possible to include lower than 10 pins.  I commonly get 4 pin Inductors or Filters as shown below in slightly different sizes and pad dimensions.
In addition, the engineer commonly wants to change the pad size based on design requirements and the Manufacturer recommended feature would work great for this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2012 at 1:52pm
4-pin Chip Array's have been added to V29 release so you can now build this type of component.
