  New Posts New Posts RSS Feed - BGA Pad Size Does Not Scale With N, M and L?
DaveCowl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCowl Quote  Post ReplyReply Direct Link To This Post Topic: BGA Pad Size Does Not Scale With N, M and L?
    Posted: 25 Oct 2012 at 2:28pm
I created a land pattern for a Micron memory part BGA and I notice that when I change between N, M and L, there is no change in pad size. It is 0.8mm pitch and 0.45mm ball diameter.
Also, as was mentioned yesterday, I am curious as to whether the pad size should be the same as the Solder Mask, or whether the Solder Mask should create the pad opening on a larger copper pad...
In any case the following table indicates that the pad size should change with N, M and L - what is best to do here?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2012 at 4:04pm
IPC-7351 only supports 1-Tier for all Grid Array package pad size calculations.
The BGA ball collaspes around the pad edges -
The 3-Tier for the BGA only changes the Silkscreen Line Width, Ref Des Height and Local Fiducial sizes for fine pitch BGA's.
