  New Posts New Posts RSS Feed - Add Family for Bi-Directional Diodes
caclark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caclark Quote  Post ReplyReply Direct Link To This Post Topic: Add Family for Bi-Directional Diodes
    Posted: 25 Oct 2012 at 7:32am
As of late I have been overwhelmed with creating TVS Diodes that are Bi-Directional. However in both the "Chip" & "Molded Body" for example there is only 1 family option for diodes, and these include polarity markings on both the Legend and Body Outline layers which I have to remember to manually remove from each part.
Datasheet example: http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00279657.pdf
Need to have a "Diode, Non-Polorized" family added to all Component Types that currently include Diode as a family option.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2012 at 10:43am
A Bi-Directional Diode just has Pin 1 and 2 and not A & C.
We'll add a new feature that allows you to query the Diode Pin and change the Pin Names.
Or do you want a new component family for DIOMB = Diode, Molded, Bi-directional?
Post Options Post Options   Thanks (0) Thanks(0)   Quote caclark Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2012 at 11:37am
I am not sure about anyone else, but I would prefer a new component family.
1. To keep it consistent with the other Polarized/Non-Polarized family components you already have in the Chip & Molded Body component types.
2. It is more than just the pin naming, it would also involve the polarity (or lack of) markings applied to the assembly & legend layers as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2012 at 1:56pm
Bi-Directional (non-polarized) Diodes for both the Chip and Molded Body component families have been added to the V29 release.
Since these are nonpolarized, the pin numbers are 1 & 2 (not C & A).
This page was generated in 0.828 seconds.
