  New Posts New Posts RSS Feed - FPX Editor - Pasting Data in Multiple Columns
Matthew Lamkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matthew Lamkin Quote  Post ReplyReply Direct Link To This Post Topic: FPX Editor - Pasting Data in Multiple Columns
    Posted: 03 Oct 2012 at 4:32am
1)      When creating a new column in the list of parts, I am unable to select multiple cells and paste information in like I can do with a spread sheet.
I think it needs to be able to do this so a user can easily add similar data on the parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2012 at 8:59am
The workaround is to open your FPX file in M/S Excel and do all your automated text editing.
Then select all Cells by "Ctrl + A" (Select All) and then Copy - Ctrl + C into Notepad and then File Save_As your FPX file name.
I use Excel for performing mass editing of our FPX files. It's extremely productive.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2012 at 6:16am
Open Excel > File > Import > All File Types > xxxx.fpx > Tab Delimiter > Separate (open) Columns
Edit all you want, but I would not change any info in Columns A or B. Column "A" is the Component Family which opens the correct Calculator menu. Column "B" is the Units, Family and Component Dimensions. I gues you could edit the Component Dimensions if you know what you're doing.
When Excel editing is completed, select all active cells (Ctrl + A) and Ctrl + C (Copy) and then open Notepad Text Editor and Ctrl + V (Paste) and "File Save As" xxxx.fpx.
Open the file in the PCB Footprint Expert and test it out. It may take some people a couple attempts to get it right, but I use Excel everyday for mass FPX file editing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matthew Lamkin Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2012 at 6:53am
OK got that, I was trying to separate the data items, with them all in the same field its OK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2017 at 11:50am
You can now select any cell in Library Editor and RMB > Copy and then select multiple cells and RMB > Paste.
