  New Posts New Posts RSS Feed - TH Calculator Lead Size in AWG or SWG
jameshead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Topic: TH Calculator Lead Size in AWG or SWG
    Posted: 18 Sep 2012 at 2:17am
I have a suggestion for the through-hole calculator.
The current dimension in FPX for lead width (b) requires a proper dimension as either min/max or nom/tol +/tol -.
Some datasheets for axial and radial components specify a wire gauge size in either SWG or AWG, for example this TE fuse:
http://bit.ly/OA0tk6
It'd be nice to either have AWG/SWG and the dimensions available, perhaps in the "Convert" button, in FPX so the dimension is quickly available to the user.
 I thought it might be nice to have AWG or SWG available as an option instead of the b dimension for the axial and future radial calculator as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2012 at 2:40pm
We added new Wire Gauge Charts here -
http://www.pcblibraries.com/downloads/Guidelines!ANSI_Wire_Gauge_Charts.asp
The wire diameter and the recommended hole size is listed.
Use the Proportional Padstack Chart to figure out the rest.
