"S" dim for DFN 2 Pin & Avago template request |
jameshead
Topic: "S" dim for DFN 2 Pin & Avago template requestPosted: 17 Sep 2012 at 1:10am |
I used the Dual Flat No-Lead (DFN 2 Pin) calculator to create a footprint for an Avago ASMT-Bx20-AS000 LED since it seemed the closest match.
Datasheet here: http://www.avagotech.com/docs/AV02-0389EN I entered pitch as 2.65 mm to begin with (3.2 mm - 0.55 mm) along with the other dims that match up well. Clicking Footprint and Dimensions after the calculation to enter the manufacturers recommended soldering land pattern and there's no S dim in this calculator. May an S dim be added for times users want to "adapt" a calculator to a device? I went back to the component dims and changed the pitch to 3.1 mm (4.2 mm - 1.1 mm) to get around it, and re-entered the W and L dimensions from the manufacturer's datasheet so easily worked around but thought adding an S might be neater. Can we have an Avago template added? |
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 6032 |
Thanks(1)
Posted: 17 Sep 2012 at 8:21am |
Can you please create and send me a Avago template and I'll add it to the installer.
The component family for this part - http://www.avagotech.com/docs/AV02-0389EN is the 2-pin "Side Concave Diode/LED" - ![]() |
jameshead
Posted: 17 Sep 2012 at 8:32am |
Thanks Tom, I'll e-mail you an Avago template directly.
