  New Posts New Posts RSS Feed - Chip Component Land Pattern
bakhmat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakhmat Quote  Post ReplyReply Direct Link To This Post Topic: Chip Component Land Pattern
    Posted: 13 Sep 2012 at 7:38am
Hi all,
How can I calculate Gmin for chip component (IPC-7351B)?
I can't get the PCB Footprint Expert result.  Confused
Gmin=Smax-2*JH-SQRT(Cs^2+P^2+F^2), where
Smax=Smin+Stol(RMS);
Smin=Lmin-2*Tmax;
Cs=Stol(RMS);
Stol(RMS)=SQRT[(Lmax-Lmin)^2+(Tmax-Tmin)^2]
JH=0 (Nominal Density for 0603 chip component)
P - placement tol.; F - fabrication tol.
Is that right?
Thanks in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2012 at 2:31am
For those who want to customize library rules to meet manufacturer’s requirements and want to see how it works to create customized Footprint Expert DAT files (personal rules).
IPC-7351C Reference Calculator  (forum login is required to download)
This page was generated in 0.656 seconds.
