Forum Home Forum Home > Libraries > Schematic Symbols > DxDesigner
  New Posts New Posts RSS Feed - Refdes and symbol for a sensor
Nightwish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nightwish Quote  Post ReplyReply Direct Link To This Post Topic: Refdes and symbol for a sensor
    Posted: 04 Sep 2012 at 12:17am
Hi All,
I am creating a symbol for two pin sensor but don't know what the symbol should be like and what about its refdes. Wish you can give me some suggestions on it.
If IPC has a definition on the symbol or its refdes?
Thanks in advanceSmile
Nightwish
jameshead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 1:29am
What's the sensor for?
BS 60617 has symbols for a Proximity Sensor device, Capacitive proximity detector, touch sensor, magnetically operated proximatry switch etc. and also a symbol for "signal translator".
If it's something not covered elsewhere I generally use the symbol for signal translator and put something near by to indicate what it is sensing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nightwish Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2012 at 9:41pm
Hi Jameshead,
Sorry to reply you late. This is a ultrasonic sensor from Murata. I don't know if there is an universal standard on this.
Nightwish
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 1:24am
I'd use a microphone symbol for this and maybe put the frequency range under it just to show that it's not a normal microphone.
There is another used symbol though:
This page was generated in 0.268 seconds.
