  New Posts New Posts RSS Feed - Odd Looking Footprint for Chip Array
LaserAlex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaserAlex Quote  Post ReplyReply Direct Link To This Post Topic: Odd Looking Footprint for Chip Array
    Posted: 25 Aug 2012 at 2:03am
I was trying to create a footprint for a small (quad 0201) Panasonic chip array resistor.  The footprint created by PCB Footprint Expert has really skinny lands, when compared to both the manufacturer's recommended footprints and the Mentor IPC footprint calculator I got with my copy of the IPC standard.
Is this a bug, or has the standard changed?
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2012 at 8:51am
With 0201 microminiature components, less solder is sometimes best and according to the IPC-7351 mathematical model that's true.
However, if the component manufacturer did their due diligence and tested their recommended pattern and it passed all stress tests then I would consider using it. That is why we built into the new PCB Footprint Expert the ability to enter the component manufacturer recommended pattern dimensions.
Every component family has a "Footprint" tab. After you insert all the component dimensions and select "OK" to calculate the IPC pattern, select the "Footprint" tab to compare the IPC pattern with the manufacturer's pattern dimensions. If they're way off, select the "Use Manufacturer's Recommended Dimensions" button and enter the pad length, width and separation dimensions and build that pattern. The IPC rules for Courtyard spacing will be auto-calculated and the silkscreen will be auto-trimmed to follow your silkscreen to pad rule.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaserAlex Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 12:41pm
Thanks, Tom.
I'm OK with the general idea of entering the manufacturer's preferred footprint.  However, it doesn't explain why PCB Footprint Expert gives a different recommended footprint than LP Wizard.  If they are both using the same version of the IPC standard for their calculations, they should both produce identical land patterns.  The fact that they don't seems like a possible bug to at least look in to.
In the mean time, I have created a footprint according to the manufacturer's instructions, I just want to make sure this doesn't cause a problem for any other users in the future.
Regards,
-Alex
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 12:47pm
The PCB Footprint Expert is a brand new tool that was written from scratch and during the process we discovered some mistakes we made with LP Wizard.
Also, the new program uses a higher resolution of 0.01 mm snap grid round-off while LP Wizard uses a 0.05 mm round-off.
If there are differences, they should only be 1 or 2 mils.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 12:48pm
Can you send us the datasheet (or link) for the part you're creating so we can check it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaserAlex Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 1:48pm
Sure, here's a top-level link:
The catalog with dimensions is here:
and the recommended footprint is here:
If you look at the image in my first post, you'll see that Footprint Expert makes pads that are half as wide and twice as long as the recommended land pattern.  The LP Wizard comes up with something pretty close to the manufacturer's recommendation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2012 at 8:23am
To summarize, the significant differences are:
1.       In the Toe Goal…the manufacturer is ignoring the IPC toe
2.       In the Heel Goal…the manufacturer is ignoring the IPC heel
3.       LPW has a smaller IPC toe than FPX (bug in LPW)
4.       LPW has different place and size rounds. 0.05 mm for LPW and 0.01 mm for FPX
5.       Finally, LPW has a minimum pad-to-pad spacing rule of 0.20 mm so it’s heel is being trimmed more than FPX which has a minimum pad to pad of 0.15 mm.
